Re: 450 Engine Compression???
Posted by mkirsch on March 07, 2008 at 06:14:28 from (64.80.108.53):
In Reply to: 450 Engine Compression??? posted by Re: 460 is a knocking... on March 06, 2008 at 18:23:41:
Wouldn't leaking oil from the rear main indicate that the rear seal went bad? Why would you think it's compression related?
Excessive blowby won't pressurize the crankcase and blow oil out the rear main, unless the breather is plugged. More likely, you'd see excessive smoke out the breather.
