Re: IH2000 loader fit a 560D?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Rodger on March 04, 2000 at 04:58:12 from (63.13.63.187):
In Reply to: IH2000 loader fit a 560D? posted by Mylar on March 04, 2000 at 03:18:17:
Hello,
I was fortunate to find a used DuAl Model 325 (or 315-I forget which it is) for my 560D. It has just been an excellent loader with power up and down, has a 5 ft. bucket. I paid $1100 for it at a consignment auction. The 560 is what I understand is called a 'long frame' tractor and as you may already know, people say it takes a loader with longer lift arms, I guess. I'm not sure why a 'conventional loader wouldn't work, but would just make the pivot point for the lift arms nearer the front of the tractor, and depending upon the mounting brackets, they would probably have to be modified.
I'd think your planned use of the loader would be the most important factor. If its a heavy use, lot of turning when under load, then, I'd think you should be sure that the loader is properly fitted to the tractor. If its just an occasional loader use, then modifying a loader to fit the tractor, might be a reasonable option.
My DuAl is similar to some Farmhands I've seen.
I've seen a 2001 Series IH Loader on a 504, and it looked like it was almost totally on the front part of the tractor---looked pretty weak.
Post A Followup
: Re: Re: IH2000 loader fit a 560D?
