Re: 140 electrical problems
Posted by gene bender on March 07, 2008 at 16:08:38 from (67.55.226.69):
In Reply to: 140 electrical problems posted by Jimmy Lawson on March 07, 2008 at 15:11:02:
You better take the spark plugs out then take off the dist cap and check to see if the rotor lines up with the tower going to the cycl as its possible you have stripped the timing gears. You will see when you pull the plugs and turn the engine over watching the rotor turn.
