Re: 140 electrical problems
Posted by Janicholson on March 07, 2008 at 16:08:41 from (66.173.50.185):
In Reply to: 140 electrical problems posted by Jimmy Lawson on March 07, 2008 at 15:11:02:
First issue is that a 12v system needs either a external resistor in the wire going to the coil (different than the resistor on the alternator), or a coil that is designed for 12v without a resistor.
With that in mind, the coil overheated and boiled the oil inside it. This caused it to explode!. When it exploded, it may have shorted directly to ground and damaged the switch, or wiring to the ignition.
There is a wire that runs to the ignition switch from the Amp meter. From the switch a wire then goes to the Ballast resistor (see above) or the coil positive.
Make sure there is voltage to the input of the switch, then the output of the switch (when on),
then the coil wire where it comes out near the coil, and is attached (or not if none)to the resistor. If these are good, then checking the points and condenser in the distributor is next. The points may have been burnt from excess current flow when the coil blew. Good luck, Keep us in the loop. JimN
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
