Re: IH 574 Problems Starting
Posted by FromJB2 on March 08, 2008 at 08:45:42 from (99.241.179.24):
In Reply to: IH 574 Problems Starting posted by Aaron Bauman on March 08, 2008 at 06:57:44:
Hi Aaron, is this a gas or Diesel? Does it have Lucas or Delco starter. Does it have a clutch starter lockout safety switch? Make sure battery cables and connectors for both starter and ground are clean and making good connection. Do any of the head or fender lights work, if so turn the lights on before attempting to start tractor and then try the starter, if lights go completely out then there is a bad battery or connection problem.
My brother just had similar problem with his Lucas starter on 454. If yours is a Diesel and Lucas starter it would be same as my brother's 454. Solution was replace starter solenoid switch and starter drive.
JimB
