Re: PTO overrun clutch
Posted by ScottyHOMEy on March 08, 2008 at 09:27:17 from (71.241.213.254):
In Reply to: PTO overrun clutch posted by EH in KS on March 08, 2008 at 08:55:00:
Basically, it fits into the drive line, between the output shaft on the tractor and the input shaft on the implement.
It lets the output shaft drive the implement, but allows the implement to spin down without driving the tractor forward when you want to stop. The usual non-live, direct drive PTO set up is a solid connection so any inertia of the implement will feed back through the gears until you get it stopped. This eliminates that.
I haven't torn into one, and may be entirely washed up on this, but suspect it's a pawl type arrangement, similar in concept to the guts of the common hand-ratchet.
Simple installation, but you MIGHT have to shorten the input shaft on your mower, if you don't have enough adjustment in it to accommodate the extra few inches that the over-run clutch extends off the tractor shaft.
