Re: 2400B (454)
Posted by FromJB2 on March 08, 2008 at 15:53:59 from (99.241.179.24):
In Reply to: 2400B (454) posted by retiree on March 08, 2008 at 13:37:16:
Retiree, could be weak hydraulic pump. Require pressure & flow guages to test. The other possibility is MCV valve but usually MCV causes problems with steering or 3pt not both. Brakes are fed off return line from hydraulic oil cooler in front of rad. Any hydraulic flow problem will always result in brake problems.
JimB
