Re: Need Farmall A Steering Sector
Posted by tn terry t on March 09, 2008 at 09:32:26 from (205.188.116.144):
In Reply to: Need Farmall A Steering Sector posted by Re: 460 is a knocking... on March 09, 2008 at 06:54:53:
Andrew Z said: (quoted from post at 04:57:07 03/10/08) Bob,
I have one off a 100 should be the same gear i can send pics if your interested. my Email is open
Thanks
Andrew
Andrew i have a sector gear out of an A in my 63 140 BUT the teeth count where different so i had to use the steering shaft out of the A slso the 140 now steers harder than it did because of the different ratio but its not that much so you will need to count the teeth
