Posted by No tools on March 09, 2008 at 19:37:34 from (71.79.47.23):
In Reply to: 706 troubles posted by Zach from TX on March 09, 2008 at 18:21:43:
OK! Went back found your original post May not help you at all.And this is very difficult to explain over the phone.(weak steering very little brakes?)
Here we go.Go back to the rear of 706 remove top link bracket.right above PTO 6 bolts. Ok now on the far right of that housing lower sensing arm from lower cross shaft.Grab it by hand see if it moves if so it has broken u bolt at bottom.Have to pull PTO.Now if it is tight(MAKE sure the top of that arm should have a 1/4 adjusting bolt in top of it with a piece made like a eagle claw on it.( NOW make sure that eagle IS IS FOR sure behind the upper sensing arm.THAT mean to the rear of tractor)
repeat lower arm to rear>> upper arm to front <<
If the lower is in front the upper it cancels HYDRAULIC action YES three point will raise but that's all you have.
NOW your steering MAY be another problem.OR OR it could be I know if the oil cooler lines have been crossed it can mess things up with the MCV valve.
Just some the things i've stumbled into.May not make any sense to you but worthing looking at.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
