Re: MD not starting for a while now!
Posted by Peculiar Farmer on March 10, 2008 at 10:19:35 from (64.19.38.166):
In Reply to: Re: MD not starting for a while now! posted by Janicholson on March 10, 2008 at 09:24:37:
Supposed to be 60+ degrees here in MO starting tomorrow so will probably attack the problem at full speed. After reading your suggestions in think, WOW, why didn't I think of that, however would not have come up with the rear wheel thing on my own. Thanks. The sediment bowl I got was supposed to be OEM however the valve handle is too long and hits the bottom edge of the tank and won't go 360 degrees. Put the old valve in for now until I can rework the new one.
