Re: H hand crank disassembly
Posted by BobinOhio on March 10, 2008 at 15:13:13 from (162.40.20.105):
In Reply to: H hand crank disassembly posted by neblinc on March 10, 2008 at 07:17:51:
I need to remove this assembly on my H too because the piece with the groove cut in it that turns the crankshaft is rounded out. Can it be removed from the bottom without taking the front bolster off? Do I just drive the pin out and it will come apart? Any suggestions on removing it? Thanks Bob
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
