Re: Farmall M Carb - Adjustment or More?
Posted by Janicholson on March 10, 2008 at 17:12:09 from (66.173.50.8):
In Reply to: Farmall M Carb - Adjustment or More? posted by Clarkbug on March 10, 2008 at 15:27:11:
Check first for a vacuum leak at the carb to manifold, in the manifold itself, or at the head to manifold gasket. Use a propane torch with the head off to allow raw propane to get into the leak areas, gaskets etc. Run the engine at the edge of not running (choke as far in as it will keep ticking over) then see if the propane will make it perk up. Do not use massive amounts, and do it outside.
If that does not produce results, I think a idle port has crud in it. Remove, assess, clean, and blow carb spray through every little passage. JimN
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
