The two things I would look at would at would be a sticking high pressure relief valve or the snap ring off the end of the shuttle valve.
If you can get the tractor to move in reverse by putting it in neutral or forward and then going to to reverse the most likely cause is the shuttle valve.
The way to test it is to put isolation valves on the high pressure lines coming out of the center section. If the problem is still there, it is the shuttle valve spool snap ring or spring. If the problem can not be duplicated then the problem is a sticking reverse high pressure valve.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
