Posted by GordoSD on March 10, 2008 at 18:44:52 from (66.115.200.140):
Last May I wrote several messages here because my 966 wouldn't crank. I had the starter rebuilt finally. Checked batteries, cleaned everything, and then it just came to life after I removed and reinstalled the starter. Yesterday same symptoms. Bright lights, good gauges, just a sharp pop, but not crank. After removing batteries, charging them, cleaning all the terminals. same result. On a hunch I jacked up one rear side,( not easy when they are frozen in the soil/ice). Rotated the tire/wheel 90 degrees and hit the stater. Fired off in about 2 revs. What is causing this? I had the engine heater plugged in, but I had not run the tractor since late NOV. It was 20 degrees ambient air temp. As a kid I remember the old "flat spot" on the Ford flathead starter. Just bump the car in 3rd gear and off you go. Is this similar?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
