Re: H hand crank disassembly
Posted by neblinc on March 11, 2008 at 05:40:50 from (76.79.15.58):
In Reply to: H hand crank disassembly posted by neblinc on March 10, 2008 at 07:17:51:
I had the bolster off when I removed this one. If you can get in there and remove that snap ring and get that piece that covers the retaining pin off it might come out.
I had to drive it out from the front by hitting the shaft to get that cover piece loose, you won't be able to do that while the bolster is still mounted, it will hit the crankshaft.
Randy
