Re: IH 186 hydro reverse problems
Posted by Allan In NE on March 11, 2008 at 05:45:02 from (148.78.243.25):
In Reply to: Re: IH 186 hydro reverse problems posted by IH Ben on March 11, 2008 at 05:05:40:
"What I would do" is to "isolate" like Owen says.
Cap off those two pressure lines at the transmission, then give 'er a good road test.
This will make it a totally mechanical controlled outfit (you wanna have 'er out in the open when doing this as there is no more "clutch" and no more hydraulic buffering of the control; it's a bang-bang shifting, in/out deal).
If the problem is still there, you would then know the glitch is in the lower unit. If however, the problem disappears, you know the trouble lies upwards in the controls/hydraulics.
Be sure and let us know what you find, okay?
Allan
