Re: Seat bracket delema
Posted by CNKS on March 11, 2008 at 17:44:33 from (216.144.104.128):
In Reply to: Seat bracket delema posted by Ray Pell on March 10, 2008 at 18:38:24:
That is not a large bracket. On similar items I have filled the pits with JB weld, sanded and then used body filler. I don't trust glazing putty or body filler in deep pits, the JB weld is permanent in that situation. A LOT of sanding, but it works. Then transfer the original tag.
