The straight gasoline engines are difficult to start if they have been sitting for some time as the fuel in the carburetor evaporates and one has to crank the engine over for some time for fuel to refill the bowl before setting the magneto to start. Most of the fuel from the pump goes back to the tank as there is only about 1/2 inch head on the line to the carburetor. Mine is an O-12 but has the same engine and fuel system. The later F-14 and the standard (O,W, Fairway) tractors with kerosene engines are easier as they have a gravity feed starter tank. Once the engine is running the fuel supply from the pump is fine.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
