Re: 450 WON'T START/ VALVES??
Posted by r4etired on March 12, 2008 at 05:33:00 from (166.145.64.41):
In Reply to: 450 WON'T START/ VALVES?? posted by Hoss357 on March 12, 2008 at 03:59:24:
Check and see if the distributor shaft is turning steady and take off the oil fill cap and listen for any noises while turning the engine over. If your push rods aren't moving it must be the cam.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
