I'm sure you are on the right track. If you turned it through at least one complete revolution while watching the valves, and only some of them have moved, the issue is cam drive. The gear can have a broken hub, the hub can have a sheared key, or the cam can be broken. Each of these can happen without having a load on the engine, and the distributor can still turn (apparent good ignition timing). Causes might include a piece of trash in the hydraulic pump jambing it just enough to shear an already worn key, A broken hub thet just hung on till time cought up with it, or a valve that stuck causing the force on a weakened drive to finally fail. If the above lack of motion through several rotations of the engine is correct, pulling the front cover is the next step. Best of luck, JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
