Re: Farmall M 1931
Posted by Janicholson on March 12, 2008 at 10:13:06 from (199.17.6.122):
In Reply to: Farmall M 1931 posted by L McThom on March 12, 2008 at 09:58:03:
M Farmalls were first made in 1939, So if it is an erly tractor, it may be a tad more valuable.
If it has pumped up tires and they are no good, and if the engine is stuck, It might start at $400
If it is unstuck, (engine will turn), and the tires are usable to good, high might be $1500
Post the serial number (on right frame rail by the engine I think) and we will help identify. JimN
