Re: 400 Hydraulic System
Posted by 1958johndeere620 on March 12, 2008 at 17:27:40 from (12.25.55.128):
In Reply to: 400 Hydraulic System posted by Paul in WI on March 12, 2008 at 13:57:50:
Put a gauge on the pump. That would tell you if the problem is the pump or the valves. It is supposed to have 30 to 60 psi with valves in neutral and 12 to 1500 psi at high pressure. It sounds like you have no pressure as you said the motor does not lug when levers moved. The trouble shooting section of my book says
1 Loss of fluid
2 pump failure
3 Faulty pressure regulator valve
4 leakage past lift cylinder seals ( not likley as all of your valves stopped at same time )
5 plugged intake screen
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
