Re: 400 Hydraulic System
Posted by Arlen -MN. on March 12, 2008 at 19:27:45 from (204.248.125.142):
In Reply to: 400 Hydraulic System posted by Paul in WI on March 12, 2008 at 13:57:50:
You need to prime your pump. Make sure you have enough oil in the resevoir. Remove a slotted plug on the pump. It has a spring and a steel ball check valve under it. Remove these ( be carefull not to lose them) and pump in oil with a pump oil can. Replace all parts and try it. This has worked for me many times.
