Re: Super M float stuck
Posted by CENTAUR on March 12, 2008 at 19:32:44 from (66.75.6.62):
In Reply to: Super M float stuck posted by Tractorfan1 on March 12, 2008 at 18:27:32:
Shut off fuel supply by disconecting or shut-off valve.Then start up and run at fast idle till it runs out of fuel,then reconnect fuel and flush out any dirt that may be between the needle and seat. CENTAUR
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
