Re: Replacement brushes for Delco Remy Generator
Posted by aaachris on March 13, 2008 at 11:55:49 from (216.13.140.10):
In Reply to: Replacement brushes for Delco Remy Generator posted by Gale Roberts on March 12, 2008 at 17:14:48:
I have purchased many genny parts from
Weitzel"s DC Electric
Norwalk Ohio.
419-668-2844
1-866-840-2844
Great folks to deal with. Your "kit" will cost about 10 bucks and you get the three brushes, front bearing (sealed) so you dont have to lube the front, and a new rear bushing.
It helps if you have the Delco Remy tag on your genny, but if not he can match them if you email a pic of your old brushes. Probabally slide in brushes. Hopefully the retaining springs are still good as no one makes them anymore... you would have to make your own.
Hope this helps you.
