Re: F-12 Waukesha came home!
Posted by Hoss in ME on March 13, 2008 at 16:52:32 from (72.224.133.167):
In Reply to: F-12 Waukesha came home! posted by gpogpo on March 13, 2008 at 13:18:49:
Its old and used up............Im going out on a limb here,how bout 50 bucks.Probably could getcha 12-1500. Later Hoss
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
