Re: That's Better!
Posted by Armand Tatro on March 13, 2008 at 17:45:17 from (67.176.252.97):
In Reply to: That's Better! posted by Allan In NE on March 13, 2008 at 09:47:12:
Alan if you cut it at the right spot you will not have to drill any new holes. I was lucky enough to find a broken drawbar and did not have to drill any holes. As I recall we used original brace rods. Will have to check with my son. Armand
