Re: Hydro-Touch Control Valves
Posted by Hugh MacKay on March 14, 2008 at 02:57:13 from (216.208.58.181):
In Reply to: Re: Hydro-Touch Control Valves posted by Lynn Kaufmann on March 13, 2008 at 20:20:10:
Lynn: Farmall 300 equipped with 2 or 3 valves always used the valve closest the reservoir for fast hitch. Bear in mind that is the extreme right lever, and the lever must be pushed forward for raising. Always, the valve on extreme right was used for loader, again this is the lever on the extreme left. If equipped with a 3rd valve in center, and it operated depth control cylinder on hitch, hydraulic bucket or right side cultivators.
In all cases 300 control valve levers must be pushed forward to extend a hydraulic ram.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
