Mike - you don't need the generator/VR to run the tractor. (The ignition and the generator/voltage regulator are two completely separate systems that just happen to be connected to the same battery....each operates completely independently of the other.)
To wire the ignition, simply run a wire from the ammeter terminal that's NOT connected to the batterr. Run this wire to either terminal on the ignition switch. Run a 2nd wire from the other ign switch terminal to the coil primary terminal that's NOT connected to the distributor. That's it!
As long as you've got a charged battery the tractor can now be started and run.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
