Re: I need some wiring questions answered
Posted by Jim Becker on March 14, 2008 at 10:27:52 from (71.170.123.240):
In Reply to: I need some wiring questions answered posted by Mike CA on March 14, 2008 at 08:28:49:
If the generator and regulator are on the tractor, either remove the generator belt or take the wire off of the "F" terminal of the generator. This will make sure the generator doesn't try to charge, which could cause problems if it isn't properly wired to the battery.
Don't hook it back up until you are ready to work on the charging system.
