Re: Need help bad. going insane
Posted by Janicholson on March 14, 2008 at 16:56:04 from (66.173.50.50):
In Reply to: Need help bad. going insane posted by bigfutty on March 14, 2008 at 16:35:37:
Firing order is 1342
the distributor (from the back) turns clockwise and has the wires positioned:
2-1
4-3
If these are correct, there may be an intake leak to those cylinders. Use a propane torch with the tip removed to put raw propane around the manifold (if the cylinders pick up, there is a leak. If this does not work, the next plan would be to put a tablespoon or so of fuel in each of those spark plug holes to see if giving it some direct fuel makes it take off. Keel up informed so we know what you find. JimN
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
