Re: Need help bad. going insane
Posted by Haas on March 14, 2008 at 18:31:01 from (12.65.18.236):
In Reply to: Need help bad. going insane posted by bigfutty on March 14, 2008 at 16:35:37:
If you have good compression and spark and the timing is good, the tractor should run. From your description, you don't say anything about checking the valve clearance. So if you have not done than, pull the valve rocker arm cover off and adjust the valves per the manual. If you don't have good intake suction on 1 and 2 cylinders, it sounds like exhaust valves are open when they should not be, or since you have good compression, the intake valve is not opening at all. You may find that push rods are bent of have jumped out of the seat in the rocker arm.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
