If you're not concerned about it being a live pump, you can get by much cheaper with a PTO pump...
Or you can use the same type pump and get creative with how to power it so you don't tie up the rear PTO shaft, this one is mounted where the belly pump was...
Or you can run a similar pump off the belt pulley drive, just have to make a coupler and mount for it.
Beyond that, there are several options for live hydraulics that can be driven from the distributor, a cogged belt, chain, shaft, or v-belt from the crankshaft as well. A v-belt driven pump may or may not generate enough pressure, depending on the GPM you need... I'm tempted to try one of the 2-stage log splitter pumps on my next set up.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
