Re: Live hydraulics for H
Posted by Charlie M on March 15, 2008 at 05:21:29 from (70.101.104.228):
In Reply to: Live hydraulics for H posted by Tomac on March 15, 2008 at 03:48:46:
I'm surprised anything you can pull with an H that you can't lift it with the belly pump. Does it have enough oil and the right kind of oil. Lots of people want to put hydraulic oil into a belly pump they were designed to run on 30 wt non detergent oil. A dealer once told me to go to 40wt on my M.You may want to put a gauge on your current system and see what it's doing before spending a lot of money on a live system.
