Re: Need help bad. going insane
Posted by Brownie450 on March 15, 2008 at 06:22:40 from (216.51.158.221):
In Reply to: Need help bad. going insane posted by bigfutty on March 14, 2008 at 16:35:37:
Jim is right in that #1&2 may be reversed in the distributor cap. Have you tried switching # 1&2? Valve clearance should be checked also. With compression being even like it is, check all other possibilities for trouble before digging into engine. Crack in distributor cap between # 1&2 ???
Could there have been crud gotten into the lifter sockets that would have affected the valve clearances after the engine turned over a few times. never assume anything--check to be sure.
