Dad had, I think a 48 H, we put a pump ahead of the dist. I think it was a 300 pump coupled it with a dual valve system. We also used the H reservoir by using an elbow and 10 inch piece of pipe with a cap with a vent in the top to let pressure out that is created by the new pump. This pipe was installed in the filler hole. This set up would lift anything we ever wanted without an outside oil tank. After dads death the 3 of us descendants each got a tractor, my sister has the H up in Iowa so it is possible to get pictures. It's worked since 1963 and has been pushing snow all winter.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
