Re: super a 6 volt amp meter
Posted by Janicholson on March 15, 2008 at 20:01:38 from (64.83.197.92):
In Reply to: Re: super a 6 volt amp meter posted by farmall300u on March 15, 2008 at 17:19:10:
Sorry to disagree, but the issue is not a formula, it is the fact that measuring Amps is not sensitive to voltage at all. It is curent flow in (6.242X10 to the 18th electrons passing one point in one second, a coulomb)a conductor.
The only issue is sizing it to the rate of flow. In this case, the generator will put out 15 amps max, and a +20 and -20 amp meter is best. With respect, JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
