Re: Optimum battery cable size for 12v?
Posted by Janicholson on March 16, 2008 at 04:09:11 from (66.173.50.78):
In Reply to: Optimum battery cable size for 12v? posted by Mike CA on March 16, 2008 at 00:25:26:
The optimum size is also 00 gauge. Though 0 will do well. Resistance is the shortcoming of all DC power conductors even up to 240 volts. If your cables are conductive, they increase the stability and reliability greatly. They also look substantial. If you are going the rout of 12v with generator etc. then having the cables look 6v is also a consideration. Wimpy #4ga wire is common on auto applications, but do not play the right part on a tractor. JimN
