Re: Farmall A Magneto No Spark (Ideas Please?)
Posted by Peculiar Farmer on March 16, 2008 at 11:45:31 from (74.209.15.202):
In Reply to: Farmall A Magneto No Spark (Ideas Please?) posted by dunniteowl on March 16, 2008 at 10:52:18:
Like JT says, clean the points with a point file or use a piece of emery cloth just to give them a quick shine. I test mine afterwards with one side of jumper cables. Clamp one to the mag housing and the other end to the base of a spark plug. Connect a plug wire from the #1 position on the cap to the spark plug and spin the drive by hand without getting a jolt.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
