In the input shaft it looks like the outside race of bearing is still there and not all the way forward, so the ring grove is just covered by the race. I don"t have a puller to get them out so I carefuly take a die grinder and make the race thin in one or 2 spots,then take a punch and bust it and pull it out. On removing the rear bearing of input shaft, screw the bolt with a few washers under it in the end of shaft tight. Hold the shaft by the gears in two hands with end of shaft down. bring end of shaft down hard on a solid surfice. Only had one bearing out of many that would"nt jar down off shaft in one to eight licks. M&W must have made several small changes to there units over time, but all I messed with (10 plus) had a snap ring in the input shaft. If the race goes in correct I don"t think the ring holds anything most times, because it goes in tight. Once you ask about how thin the back part of M&W shaft is. There only about .063 at rear part and about 2.050 inside with race out. If I remember correct the ring grove is 5/8 inch in from rear of shaft. If you get a new pilot bearing from aftermarket, watch for quality, I learned the hard way by ordering one last month and it was so inferier to original that I would"nt use and they would"nt take it back, $68. Have removed several regular input shafts with race retaining ring missing that caused no problems. Believe your grove may still be there though.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
