Vacherie: There are spring loaded friction pads in the pivot of each hydraulic lever. Either the pad is worn, and need new pad or adjustment.
Quite often adjustment doesn't work, mainly due to rust. I've taken that whole assembly off, completely disassembled the levers, cleaned every part, then apply a dry lubricant. I did my Super A and 130 about 15 years ago. Before I started I stopped by CaseIH and picked up 4 of each pads and springs. I didn't use 1 pad, or 2 springs. My guess is this chore will only hit you every 35-40 years, I havent had to do my 140 yet.
I suspect those gave more trouble if the tractor was equipped with cultivators and side dresser. The cultivator would create more lever use, and the side dresser more corosion.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
