Re: auxiliary valve repair 656
Posted by Owen Aaland on March 17, 2008 at 02:45:42 from (65.161.86.122):
In Reply to: Re: auxiliary valve repair 656 posted by Jerry Gilliam on March 16, 2008 at 18:54:22:
Replace item #8; Piston assembly, unlatching Part # 396582R1. That is the little pin with the tiny O-ring installed. Also replace item #s 14,17, and 19, all O-rings. Part numbers: 359158R1, 380839R1, and 395278R1.
The pin assembly number I believe is still a good number. The O-ring numbers will have to be crossed to current part numbers.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
