Re: SW-6 Negative charging
Posted by Janicholson on March 17, 2008 at 06:04:32 from (199.17.6.122):
In Reply to: SW-6 Negative charging posted by AOOC on March 16, 2008 at 17:36:26:
As the others indicate, it needs to be checked with a volt meter to make sure it is actually charging. A good battery will run a Farmall/IH for as much as week of use before failing to start. If the gauge reads "0" with nothing on, then if the lights are turned on, it reads discharge, and if the tractor is running at 1/2 throttle or above, it still shows discharge, it is in need of repair. Use the search for box above for finding John T charging system steps. THat in concert with Bob M wiring diagrams are the eventual answer. JimN
