Re: 706 hydraulics
Posted by jw806 on March 17, 2008 at 17:52:42 from (69.66.143.64):
In Reply to: 706 hydraulics posted by Zach from TX on March 17, 2008 at 17:26:30:
The front (mcv) pump draws oil through the same hyd. filter as the rear or hitch/aux. pump does. With the filter and the tin baffle out, you should see that there is a oil passage cast into the houseing going forward. Hope this helps.
