Easiest way to test glo-plugs is using an analog multi-meter on low ohms scale. Remove the wire from the glo-plug in question & hold 1 lead from the multi-meter to the glo-plug connection, & the other lead to ground. A good plug will register on the meter. A bad one will register infinity.[open]
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
