Re: bolt grade difference?
Posted by rustyfarmall on March 18, 2008 at 08:13:10 from (209.152.78.71):
In Reply to: bolt grade difference? posted by Mike CA on March 17, 2008 at 18:05:51:
Mike, the grade 5 will be just fine on an H, especially when you consider how you will be using the tractor. Use the grade 5s and don't worry about it.
For what it's worth, the correct size and length of bolt, with the correct length to the threads, will be found only at a machinery dealer. Not likely you will ever find them at a common hardware store.
