Posted by D Slater on March 18, 2008 at 20:35:18 from (71.182.17.85):
In Reply to: Farmall 400? posted by Hoosierproduce on March 18, 2008 at 19:52:04:
Don't think you would want to do it. First the 400 radiator is to tall for the M grill. To mount the M gas tank the hydraulic unit and valves would have to go, then you would need a SMTA hood. It can be done by bolting a M front bolster on the 400, M radiator and shroud, lower collant pipe and shorten upper hose. M steering worm shaft, center steering shaft bearing and gage mount from a M. M hood will work now. Modifiy or make a rear gas tank support for M tank. But you would have to do something about hydraulics if wanted. Realy if you had shift forks for a MTA to add to a SM type transmission top cover and cover put on 400 about any part of a stage 2 SM or SMTA can be bolted on one way or another to work without any cutting or drilling. Don't think its worth the trouble unless you have parts laying around.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
