Posted by Hugh MacKay on March 19, 2008 at 02:39:37 from (216.208.58.179):
In Reply to: 1966 Farmall 140 posted by joseph L on March 18, 2008 at 21:51:19:
Joseph: You say new pump and box, by box do you mean the touch control unit? I presume you put a new kit in the unit, right or wrong?
You speak of heat buildup, and the most common reason for that to happen with these is stroke of hydraulic levers is not in sequence with stroke of rochshaft. If that hydraulic rockshaft reaches the end of it's stroke either direction, yet the lever is trying to force it further, that will create demand on the system and when demand occurs and it stays on demand your going to get heat.
To check this out, set your tractor at low idle and running. Move both hydraulic levers to center. The slowly move each lever, one at a time, to each end of it's stroke. Listen carefully for change in engine sound. If engine labors with either lever at either end of stroke, then lever is out of adjustment.
Dirt within the unit can also create demand, however that will not likely change as you move the levers. Do the above, then report back your findings. We'll nail this.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards
... [Read Article]
Latest Ad:
[More Ads]
