Re: questions about Super C rockshafts
Posted by kirby warfield on March 19, 2008 at 08:31:35 from (24.95.138.46):
In Reply to: questions about Super C rockshafts posted by riverbend on March 18, 2008 at 17:08:43:
That gap is not unusual,the inner rockshaft arm is part of a through shaft that works with the Touch Control cylinder. The outer arm is attached to the shaft that works the opposite side arm.the arm is tapered and keyed,as others have stated,sometimes the arm is loose on the shaft,and gives wear in the key-The retaining nut is 1 7/16" socket size.Those "ears you refered to as #2,are for implements like a planter or fertilizer unit "Throw-in or out" for C"s and SA"s,as arms are the same.Sc with Fast hitch will use a different arm.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
