Re: Harley Davidson to the rescue
Posted by GordoSD on March 19, 2008 at 09:01:56 from (66.115.200.140):
In Reply to: Harley Davidson to the rescue posted by Mike CA on March 18, 2008 at 19:34:28:
You could have saved that 30 bucks. Motorcycle tires can be hand mounted easily. I used to do some desert racing, and if you couldn't pull a tire and fix a tube, and mount it back up in less than 10 minutes, you just didn't go racing. All you need is a couple of crescent wrenches. Or a pair of those little spoons that come in some MC tool kits.Something else you could learn.
Gordo
